configure iparp delete
configure iparp delete ip_addr {vr vr_name}
Description
Deletes an entry from the ARP table.
Syntax Description
ip_addr Specifies an IP address.
vr_name Specifies a VR name.
Default
If you do not specify a VR or VRF, the current VR context is used.
Usage Guidelines
Removes any IP ARP entry (dynamic or permanent) from the table. You must specify the IP address of the entry to delete the entry.
The following command deletes an IP address entry from the ARP table:
configure iparp delete 10.1.2.5
Platform Availability
